Harness Cut
1252 Views 5 Replies 3 Participants Last post by  musthavebeenblue
anyone have a schematic of their Race cut Harness? I have been studying the schematic for a while now and am trying to figure out what can stayand what can go, i think i've got most of it figured out but instead of just cutting connectors off, i'm pulling the whole wires out. They are all spliced with other stuff so i need to make sure i keep everything needed to run.
thanks sidewinder, but i am looking for a gutted E-start harness... No headlights, no Throttle sensor, neutral sensor, clutch sensor, etc. Fully MX harness but nothing but what you need.
i see in the schematics that you call for a capacitor.. what are the specs that i'll need before trying to get one (size volts amp w/e ) ??
QUOTE (MustHaveBeenBlue @ Mar 9 2009, 02:54 AM) index.php?act=findpost&pid=755556
i see in the schematics that you call for a capacitor.. what are the specs that i'll need before trying to get one (size volts amp w/e ) ??[/b]
You'll just need one with a high enough capacitance. The one I've got on mine is a 4700 µF that I picked up from radioshack.
thanks.. but as far as just cutting the wires.. i should be fine and not have to worry about blowing the stator if i just cut them and wrap them up tight.. the capacitor i assume is taking the place of say the headlights and the taillights.. there will still be enough draw on the stator
