ya it makes them a little tight though
personal preference really, most people that stand up alot prefer the taller bars so your not bent over as much.Do these help a lot?
Which one did you get? 2" riser didn't affect your cables?personal preference really, most people that stand up alot prefer the taller bars so your not bent over as much.
i have a houser +2 stem, running all stock cables except brake lines, but im pretty sure the stock ones would fit the bars, just not the a arms.Which one did you get? 2" riser didn't affect your cables?
you probably wont need anything, there is a clip on the stock brake line that holds it to the frame, take that clip off, and it will give you much more movement...so what everyone is saying if i get a +2 stem or risers i just have to change the brake cable?
URMOSI makes a clamp+riser for the stock YFZ450 steering stem.Are there any risers that fit a stock steering stand for an 07 YFZ 450
