I'm looking to pick up a jetting kit, and wondered if there is any difference between the GYTR kit and a kit I've seen mentioned a couple of times on this board, the JD jetting kit. Which is better? Where is the cheapest place to purchase the JD kit?
Thanks in Advance. :what
the JD kit comes with 2 triple tapered needles. the only place I know you can buy it is at www.thumpertalk.com, I bought it just for the needles as the pilot and MJ's that come with it are standard Keihin jets you can pick up at a Yamaha or Honda dealer.
the leaner needle (red) that comes with the JD kit is suppose to be pretty close to the GYT-R needle.
The JD kit I have heard is a little better because of the taper of the needle but I say save $25-35 bucks and just buy the main or mains you need $3-4 bucks each, and the pilot $3-4 bucks each, and a YZ450F needle for $12-15 bucks, part #5TA-14916-V1 that is the same needle that comes in the GYTR kit.
