hey i finnally got my gytr jets from my dealer only took 2 months but i have my gytr exhaust on now wondering what jets i should put in? will the clip 3 down on the needle and a 165 be plenty. i have no idea what to do with the pilot, which one to put in? if any one can help then please do i am goign to try to tear my carb apart myself all i have to do is turn it and take that bottom nut off to my understanding don't look to hard. what color should the plug be if running good?
Hey.....
if you are running the stock airfilter, you should be good with a 168 main and a 45 pilot, stock needle, fifth clip, if you are using the yzf needle, put it on the 4th clip. Probably around two and a quarter turns on the fuel screw. I have been back and forth. I was running a 178, and the plug was black, but it screamed like mad. I dropped to a 170 and it ran ok until Wide open throttle, and it would bog a little, but the plug color was good (brownish grey). So now with the cooler weather I am running a 175 and it seems to run great. I have a k&N so the flow is better than the stock filter, thats why I think a 168 shoudl suit you well. Good luck...
Maxx
