Lazarus, what is your response to this quote ?
Hey Lazarus as usual thanks for the brain candy with the dyno data...... Been waiting for you to chime in on the yahoo 400ex forum with any insight..
What are your thoughts on this quote
" First of all, on the new Yamaha the angle of the front A-arms is such where you will have to run the first part of your suspension extremely soft for the little bumps which will cause rolling in the corners compared to a Honda or a Gas Gas and even the Suzuki that are laid back farther at an angle that allows the suspension to be stiffer but yet soak up the small bumps. The handlebar to seat relationship felt like I was riding a Breeze instead of a full size machine. The footpegs were very high so I felt scrunched up on the machine. Maybe it's built for people 5 foot and under but I was very uncomfortable on it. Motor-wise, it has little or no flywheel and was very easy to stall on a smooth moto-cross let alone a rocky, rutted out cross-country course. The motor lacked torque and has little or no way of making a big, torqy motor out of it except for maybe an 80 over piston which is only going to make it stall even easier and with the small battery that's not going to be a good thing if you have to start it all the time. I am sure with a higher steering stem and maybe some Pro Pegs that are lowered the machine might feel better but the handling and the motor are going to be a bigger obstacle for cross-country riders. Everyone that has ridden the Gas Gas was very comfortable on it and adapted to it quickly. "
And last but not least as a follow-up how would you compare the Gas Gas 450 to the new yammy especially in a cross country atmosphere........
Regards
Triston
