Be warned, replacing the seats in the FCR carb can be a pain in the ass and cause other issues if the mid body gasket starts leaking.
What I do instead in chuck a Q-Tip into my drill and "polish" the seat. Spray the swap with carb cleaner and just start running it lightly against the seat. Repeat until it stops coming out dirty (usually takes several swabs). 99% of the time it is just crud that is preventing it from sealing. After cleaning it up, shine a light on the seat and look for pits or wear. I have only ever seen 1 personally where the seat was actually bad and had to be replaced. Replace the needle while you have it apart and you should be good to go.
