2016 yfz450r after market cold air intake upgraded Exhaust. Bike runs good but I have gas in my oli I drained it replaced the it oil and I have gas in it again in less than 2 hrs of riding. Plz help
Thank you! I’ll definitely look into it. I changed the spark which was in a horrible condition. I’m pretty much Tying up loose endsAlso one way to test is pull the ejection keep pluged in and connected to tank you turn the key a feul times to prime the pump see if it leaks. But Ive seen this issue on here before and most say injector
