1 - 9 of 9 Posts
09 Yfz450R. Can i ride a full day without a fan relay i have to use that one as my fuel pump relay and i wont get another one till a week or so. If i do ride with out it, is there any risks like over heating or messing up the electrical crap somehow? Thanks
The headlight relay is the same as the fuel pump. I would use that one instead.
If you continue to have problems after switching the relays you may have a faulty fuel pump.
As a side note...the fuel pump relay location is directly under the access hole for the seat latch. This puts it in a direct "splash" zone each time you wash your quad. I wrapped mine in electrical tape to try to keep it from getting wet.
just bypass both of them and itll be one less thing to go bad
No it's not bad. I've made a few harnesses with no issues and I've bin running my fuel pump constantly for 4 years now no issue same goes for the fan. You can do it with a jumper wire. Do some research
Where are all the relays located?
2 in the front 1 in the back
1 - 9 of 9 Posts
