1 - 19 of 19 Posts
Hey guys, i dont know too much about that fuel mixture screw. What should i be doing with that. I heard a lot of u talk about it but im not sure really where it is and what to do. But it seems like this Zip-ty screw would be a good investment. What do u think. Check it out... ALBA ACTION!!!!
I am running the Zip-Ty on mine and I really appreciate the ease of adjustability. I can easily adjust the mixture with the engine running which really helps.
Isaac
But what do u suggest i do as for actually adjusting the screw?
I also have the zip-ty. It is the only way to go unless you are running totally stock. The mixture screw affects just about the whole throttle range. Do a search on jetting and you will find a thousand explainations of what this does.
the mixture screw actually only affects the first 1/8th of the throttle.
Originally posted by edgerat+Oct 2 2003, 01:52 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (edgerat @ Oct 2 2003, 01:52 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin--Thumper 450@Oct 2 2003, 08:48 PM
the mixture screw actually only affects the first 1/8th of the throttle. [/b][/quote]
i dont think thats right on an FCR. it is suppose to affect the entire circuit
Originally posted by cjpoole1+Oct 2 2003, 04:19 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (cjpoole1 @ Oct 2 2003, 04:19 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin--schwendi@Oct 2 2003, 04:45 PM
I had the kouba screw on the FCR on my Z400 it was the chit!! I need to order one for my YFZ!!
I got mine yesterday.
[/b][/quote]
from where? I want one.
although it looks like the kouba will doe the job i like the zip better since it has a knurled end and marking etched into it so is easier to know what setting it is on
Originally posted by cjpoole1+Oct 2 2003, 07:19 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (cjpoole1 @ Oct 2 2003, 07:19 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin--schwendi@Oct 2 2003, 04:45 PM
[/b][/quote]
I got it from atvcost.com along with a Power Now intake insert. I'm not real happy with the fit of the fuel screw. If its turned out more than 2 turns it is real loose and will start to turn it self out from vibration. Seems like the tolerance on the threads is not real tight. :| . I'm very pleased with the Power Now really helped the ilde to 1/2 throttle range alot. Seems to have alot less hesitation and starts a little easier.
Chuck,
mate I'd toss it, not worth the trouble it would cause if it dropped out.
Geoff.
What exactly is the power now insert? It sounds like something that would be buying. :lol
Originally posted by Aussiequadrider@Oct 5 2003, 05:06 AM
Chuck,
Geoff.
I raced a harescramble with it today and it didn't move so I think it should be ok.
1 - 19 of 19 Posts
