Fuel injected flood/fouled plug.
5K views 10 replies 7 participants last post by  jonshver03
#1 · (Edited)
Anybody ever experience this? I recently installed a PCV on my 09, started and ran great first start up. I shut it off then went to start later on. It started and stalled. Check fuel injector pulse with a noid light then proceeded to verify spark using a spare plug. Upon pulling the plug, it was soaked in fuel. There was quite a bit of cranking/no starting going on prior to checking the plug which I beleive is what caused the wet plug and it was just fouled initially resulting in the no start. Note this was the original plug and the atv has approx 8 hrs.
#5 ·
I have the same bike with a PCV and Autotune and am having problems with my oil smelling like gas. Im a trial and error type of guy so I took the throttle body off to replace the injector but the screws that hold the injector in absolutely will not let loose.
