i noticed today when i was putting on my case saver there's a rubber piece on the inside of the front sprocket. anyone know what this is for?
so your not gunna get the same dirt blockage on the shaft if you have a aftermarket sprocket?That rubber piece is only on the OEM sprocket.[/b]
so your not gunna get the same dirt blockage on the shaft if you have a aftermarket sprocket?[/b]
