Hey everybody i'm new here and im starting to build up my quad up, but i want to know whats the differences in building it up for freestyle vs mx. All i pretty much ride is track and i really want to start and try freestyle but im not sure what i need to get it set up for it. Thanks i appreciate it.
For the stuff your going to be doing just build it as if you were to be doing mx only and it'll be fine for freestyle, you hit jumps in mx. You hit jumps freestyling, the only differance is you don't do tricks in mx. It lands the same, the only thing that differs is what you do while in the air, which has nothing to do with the bike really.
id just get your shocks setup for mx...i know some of the pro freestylers get there shocks setup for mx with they weight setup for someone a lot heavier than they are for the bigger jumps, but you shouldn't need to.
Shocks is probably going to be the first thing i'm going to get. Then i was thinking about going +2 should i do anything to the rear?
An axle would be nice, somethin to balance it out.
