i just did the oil update on my 05, after running it a little, i check the oil, there are a good amount of tiny air bubbles in it now, is this common with those tiny squirters? it goes away after letting the bike sit a bit. just making sure something else isnt going on here.
im running the spectro 10-40
hey level, did you ever find any info on this? i just fired mine up after doing the squirter update and found the same thing.
QUOTE (leveldrummer @ Feb 28 2009, 11:56 PM) index.php?act=findpost&pid=752283
im running the spectro 10-40[/b]
If u look inside your oil over flow while running it does have air bubbles....So i guess its normal..
yea, nothing ever really came of it, so i wouldnt worry, just keep an eye that it doesnt foam too much and actually start to push out of somewhere.
QUOTE (leveldrummer @ Feb 28 2009, 08:56 PM) index.php?act=findpost&pid=752283
if you use rotella it has a antifoaming agent that prevents that from happening
Normal when u have the oil mods.
