Alright all you mechnics, heres my ordeal...... went out riding today and I've lost some top end speed. It ran great the last time I was out. Since my last ride the only things I have changed is (1) installed a motion pro throttle. (2) cleaned and reoiled my air filter.
I checked to make sure my throttle was opening up all the way cause I thought I might not have ajusted the cable properly but it is opening all the way.
my second guess was that I may have put to much filter oil on the filter which is causing it to choke on top. So i removed the air box lid and ran it around to see if that helped and it felt a little better.
so what do you think could a clogged filter cause you to lose top end, cause it seems fine on the bottom end????????
