also forgot.. i need lower right a arm and right shock.. any suggestions on where to get these stock?
Pretty much what he said, but a 4/1 offset front wheel will give you less bump steer. Just make sure the arms you get are meant to run that offset (most are). The 3/2 will work well, just the 4/1 is better.i would say ebay or post up in the wanted section for your needs on things. As far as width run 3-2 front wheels and arms then get you an axle for width in the rear. I dont trust in getting spacers or anything or hubs. I have always just picked up an extended axle. ANd i run xc but i think most mx guys run 8" in the rear and 10" in the front with an 18 inch tire in the rear and 20 inch tire in the rear.[/b]
