I dont personally know your problem but i do know your gunna need to give more info smoke color and/or smell (sweet) and so on.
This is a slight possibilty. I cant remember switching them but it has been a while so my memory is not really fresh. I will check it out. Thanks for the tip.For the last one with the lights, did you just switch the bulbs on accident? Since it would never overheat (causing the neutral light to come on) and the hot light comes on when you turn the key, like it would if it were in neutral.[/b]
To answer the first two the bike was NOT under a load. It was in my garage. I always thought the bike should not smoke or pop at all....meaning i thought it did not matter if the bike were under load or sitting on a stand. Shouldnt a properly running motor not smoke and not pop even if it is on a stand??Problem 1-is that bike smokes a little(very little at idle) and a litte more when you really rev it hard.
Under a load? If it's not under a load you're wasting your time.
Problem 2- The bike is popping like hell with flames shooting out of the exhaust.This happens when you let off the gas after reving it.
Under load or just sitting there? If it isn't under a load (riding it) you're wasting your time.
Problem3-The overheating light comes on as soon as you turn th key on and the nuetral light does not come on at all( even when the bike is in neutral)
Does the light stay on or does it turn on and off. If it turns on and then off that's normal. Check the sky blue wire near the shifter going into the case...may have a bad connection. Or check the wires leading from the clutch switch.[/b]
yea, the light comes on when i turn the key, but it stays on even when the quad is running. I just changed the coolant so it should not be over heating.my overheat light comes on when i turn the key, but then it goes away as soon as i hit the start button...like it needs to know theres coolant flow or something?[/b]
No the popping is not normal. You are to lean and need to go up a size on your pilot jet.as far as the popping noise, my bike does the same thing, and so did my raptor 660 after i put the HMF pipe on it, also my brother in-laws 450r does it too. its normal when at idle and in neutral reving it.[/b]
yea, its not the normal occasional decel popping. Is the flame out the exhaust a sign of it being lean as well?i would have thought that was a sign of it being rich? I am new at jetting so i am open to suggestions. What would you reccomend i go to on the pilot? ThanksNo the popping is not normal. You are to lean and need to go up a size on your pilot jet.[/b]
What size pilot do you have now? Whatever size you have now go up one size and see if it makes a difference. I runa 48 in mine with full exhaust, filter, and ncvq needle. Oh and thanks for the asv lever it looks sweet.yea, its not the normal occasional decel popping. Is the flame out the exhaust a sign of it being lean as well?i would have thought that was a sign of it being rich? I am new at jetting so i am open to suggestions. What would you reccomend i go to on the pilot? Thanks[/b]
What size pilot do you have now? Whatever size you have now go up one size and see if it makes a difference. I runa 48 in mine with full exhaust, filter, and ncvq needle. Oh and thanks for the asv lever it looks sweet.[/b]
