Pretty much where I'm at. Same weight.Originally posted by 24v@Jan 26 2004, 06:43 PM
I have everything on full soft, except the rear rebound. It is a little stiffer than full soft. The preload is still stock.
I'm 5'10" 155 lbs.
I don't really do any jumping, so that is why I set it so soft. I ride mostly dunes, with the occasional 4-5 feet of air. If you are into serious jumping, I would definetly recommend setting it stiffer than where I'm at. :rockOriginally posted by YFZdave450@Mar 20 2004, 05:52 AM
do u all do any jumping??? like atleast 50footers? i think that the suspension would bottom out. i weight 130 and want to adjust mine? what should i go with?
