Status
Not open for further replies.
1 - 20 of 23 Posts
This may be a waste of a topic, but I figured I would start a thread where members could post their jetting setups; along with altitude, so people with questions could have a resource. JIM
SEA LEVEL
CAM MOD
CURTIS SPARKS full exhaust
GYTR needle - - - - - - - - - - - 6th clip position
MAIN jet - - - - - - - - - - - - - - 178
PILOT jet - - - - - - - - - - - - - - 48
MIXTURE screw - - - - - - - - - - 1.5 turns out
AIRBOX - - - - - - - - - - - - - - - - no lid, K&N filter setup
Jetted for Dumont ~2000ft
Cam Mod
Modded stock pipe (baffle and wall out)
ESR Air Box eliminor eliminator kit with K&N
ZipTye fuel mixture screw
Main- 180
GYTR Needle- 4th clip
Pilot- 48
Mixture screw- 1.5 turns out
Jetted for mountains of southern WV ~ 1,500 - 2,500 feet
GYT-R full Ti exhaust
YZ cam
GYT-R air filter
Zip-Ty mixture screw
Main 168
Pilot 45
GYT-R needle 3rd clip
Mixture screw 1.75 turns out
I know I must sound a little lean to you guys, but it starts and runs the best with this setting and I don't have any detonation. I am going to get some type of K&N intake next, maybe that will put me closer to your settings.
desert elev. 2500-3000 ft.
glamis elev. 275 ft.
dumont elev. 1000 ft.
gytr header and alum. muffler
pro-flow with k&n filter
45 pilot
fuel screw 2 1/2 turns out
gytr needle on 4th clip
185 main jet
at these settings it starts easily, idles and accelerates smoothly. it might be slightly rich but i'll accept that rather than too lean.
2500'
HMF slip on w/ Lid off
175 Main
45 pilot
Stock needle on 4
2 turns out
Ran Great! :O
Getting ready for Glamis, gonna try:
CFM airbox with K+N (coming)
NCVQ on #4
178 Main
45 pilot
2 turns out (It runs a little rich now but maybe the K+N and altitude change will dial it in)
Sea Level (Florida)
165 Main
45 pilot
Stock needle on 5th position
2 turns out on mixture screw
No Airbox/Baffle Out
kicks ass........
will be rejetting soon as I have purchased a Full GYT-R system (ss header+alum. can), I have the YZ needle in my tool box and 168 and 170 mains... cant wait till I have the TIME to install......
Probably gonna fun a UNI filter or the GYT-R filter...
I LOve THis *hit........
45 pilot
185 main jet
I did not know that Dumont was only 1000'
I would have sworn it was closer to 2000'
Well, ill be heading out to Glamis in about a week and a half, i know its not the biggest elevation change from sea level...but will i need to change the Jetting at all???thanx
pahrump- just an estimate at 1000 ft. for dumont. Baker, Ca. is a little over 600 ft. i'll be at dumont thanksgiving and i'll try to remember to check the elev. with my gps. if you're there then let's get together.
quadfatherbob,
I will be there fo shoo, and yeah I would like to know the actual elevation.
:lol
1000'
GYT-R needle clip on 3th
170 main
48 pilot
2 turns on Zip ty
It is perfect on top, seems lean in the mid, and rich on bottom.
I'm going to put the clip in the 4th position and try 1 1/2 on pilot screw.
04 YFZ450, #47, Curtis Sparks exhaust, Cam Mod, lid off, GYT-R Jet kit, Elka's, Graydon Nerf's, GYT-R bumper, Prodesign w/K&N, Gibson Steering Stabilizer, Vortex Motion Pro Twist.
Originally posted by BryanYFZ@Dec 9 2003, 10:33 AM
:lol
1000'
170 main
48 pilot
2 turns on Zip ty
I was at the same settings as you and had the same problems.
Now I am at
175 main
45 pilot
4th clip on GYTR needle
and 1.5 turns on screw
Originally posted by schwendi@Dec 9 2003, 03:18 PM
Pahrump,
I see you leaned her out a bit ... did you have lots of carbon on the stock piston??
Yeah there was a bit of carbon buildup I was kinda surprised cause it seemed to sun good.
Runs better now, I tried the old jetting with the !3:1 first and it just frlt flat off the bottom and struggled to hit the limiter, so I leande it out a bit and seemd to perform alot better.
I still may drop the main to a 172 and see what it does.
That is if I don't have it on Methanol by New Years to try to keep up with selector :D
oh jeez .... you guys are gonna kick my arse up the hill
im actually really interested in seeing how much faster yours is than mine with the 13:1
Full Sparks exhaust, Noss K&N setup, no lid, 1300ft
YZ Needle 5th position
172 main
45 Pilot
2.5 turns out on screw
2008 SE
Cam mod
R&D Flexjet fuel screw
Powerbomb header
Trinity Exhaust
Main 175
Pilot 45 NVCQ Needle 3rd slot
Leak jet 35
Fuel screw 2.5 out from closed
Thing rips!
1 - 20 of 23 Posts
Status
