Has anyone had problems getting there ESR intake to fit with an aftermarket rear shock? If so, what did you do to get it to fit or did you? I have tried multiple ways to get mine to work but I cannot find a way that I would feel comfortable with it actually staying on. I tried to do a search for this but came up with nothing.
Thanks
Cody
Yep, doesn't fit.
FCI fits.
Ron Woods doesn't fit either.
Pro Flow with stock air tube of coarse fits.
thanks for the quick reply, I guess I will be looking into getting a FCI intake. Are they pretty good intakes?
IMO they (FCI) are the best.
I do think that the ebay Velocity intake will fit, but it may not.... and when I tested alot of intakes back in the day the Ebay one was about mid pack out of the bunch I tested. Not the best, not the worse.
When you say that ESR intake doesn´t fit with an aftermarket rear shock I suppose that is because the intake don´t fit between the frame and the shock... What is the problem?? The spring of the shock or the head of the shock??
I ask you because I'm going to install the complete Venom performance system in my ATV including the ESR intake modded by Venom. My rear shock is a stock shock modified for Supermoto. It has a little bit wider spring as you can see in the next pic:
Thanks!
