Good writeup, thanks for posting!
yes J&T still does the mod. this is the same thing that J&T will do but your machining the case and installing the squiter yourself. J&T machines your case for the squirter, installs the squirter and then sends you your case with the squirter installed and the 07 oil pump that you have to install yourself.Does J&T do this mod anymore and is this a better mod than the others? Can't I just buy a side cover from a 07 and an 07 oil pump? I really want to do this but I am really confused as to which way to go any advise would be appreciated.[/b]
exactly 3.5mm if you dont have the right machine take it to a machine shop and make sure they mill the circle only and not the two tabs that hang down. those tabs hold the squirter in place and also ask them to put a chamfer on the hole. it shouldnt cost that much. i work at a machine shop im a journeyman machinist and i could mill that down within a half hour.does the 3.5mm have to be exactly machined down or is this something I can do with a die grinder or something simular? I can easily drill the holes but dont have a local machinist.[/b]
Yes it has to be exactly 3.5mm. You could possibly use a die grinder but you would have to be PRECISE on how much you remove and make sure that it's level. I wouldn't recommend to do it that way but you could try I guess.does the 3.5mm have to be exactly machined down or is this something I can do with a die grinder or something simular? I can easily drill the holes but dont have a local machinist.[/b]
Another oil mod? Where this be at? I'm curious cuz the local atv shop here quoted me $65 for the oil mod and I thought that was basically just drilling something while this includes the squirter...is this similar to the pinned up oil mod post? but using the squirter instead?[/b]
over in the engine section, that one is drilling a hole in the case half and installing a jet, and then on the other side installing an o ring, and drilling a hole behind the oil filter to feed the jet.Another oil mod? Where this be at? I'm curious cuz the local atv shop here quoted me $65 for the oil mod and I thought that was basically just drilling something while this includes the squirter...[/b]
