Does anyone know why my start button doesn't work when I try to start the quad??
Are you getting power to the switch? If not start at the fuse and track the wire. If you have power to switch, Check neutral switch and clutch switch and ground connection
Yea the light comes on when I switch them on and when I turn the quad off the switch work its the start button not working when I press it.. is the relay suppose to click when I turn the key on??
I don't think the relay should click when the key is turned on, but should click when the starter button is pushed. Pretty sure the starter button completes the relay circuit to ground (through the neutral and clutch switches) allowing the main contacts in the relay to close allowing power to the starter.
