So I have a 2007 yfz 450 carb model that has a few deletes including tors, clutch switch, neutral switch and apparently the starting cutoff relay wired into the starting solenoid. I've had it started a few times but then went through and did a rebuild on the crank including bearings and seals. I reassembled it it now turns over and has new clutch plates and battery along with stator and rectifier. My problem is I can't get spark and I'm thinking it's because of the starter solenoid wire connector is loose but I cant figure out how the previous owner wired the starting cut off switch into it because I think I twisted 2 wires together and did it wrong. Any help would be great. I have removed the wiring harness to check for grounded wires and loose connections.
