Cutting In And Out
468 Views 2 Replies 2 Participants Last post by  spilldathrill
on my 04 when i hold it wide open, it cuts in and out, if you let off the throttle a little bit then it doesnt cut in and out. sorry if its not a very detailed description but i dont know how else to describe it. any ideas why it does that?
I can pretty much guarantee your jetting is off. I have had the same problem in the past. The right jetting will almost/ if not completely fix that problem.
You may also want to try a search next time, you might be surprised how much information is already out there for you to read before you make a post that has most likely been covered many times over.
Check out this thread...
READ THIS
Read that thread (especially "millertime47's" posts). It should give you a good idea of what direction you need to be heading.
Good luck!
