Ok i just got the complete exhuast. I also got the needle and 170 main jet kit they offer. What notch should i put the clip on when putting their needle in? Stock position? :yfz
try to turn the idle a little higher and see if that helpsOriginally posted by OutlawEX@Sep 20 2003, 09:31 PM
I bought the 170 and needle togather that sparks recomends which is most likely the dirtbike needle. When i pin the gas while not in gear it bogs down. I need to know what they set the clip at
try to turn the idle a little higher and see if that helps [/b][/quote]Originally posted by YFZ_53+Sep 20 2003, 01:39 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (YFZ_53 @ Sep 20 2003, 01:39 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin--OutlawEX@Sep 20 2003, 09:31 PM
