I am installing a normal open kill switch on my 2008 YFZ 450. I know I need to ground the coil to make the switch function. 2 wires connect to the coil, power in and to ground. What color is the wire that goes to ground? Thanks in advance
Do not connect to the coil.
That burns up coils doing that. Connect to the switch wire.
You'll either burn up the coil or shock yourself constantly when you get wet.
