which screw does which? i think upper screw = compression and lower = rebound?
please correct me if im wrong and tell me if im right.
thanks, btw, your YFZ450 garage is awesome, i like the wikipedia format =P
im setting my sag tomarrow cause i just found your article and couldnt get a clear answer any where else on how to adjust suspension. thats why i needed this thread!
thanks!
quick question, when i go over woops my rear shocks likes to bounce my rear end up to fix this I would need to turn the rebound down right
it can go both ways...
it can be caused by a rebound that is too fast or too slow...or a compression that is too soft and it bottoms out then kicks up.
get someone to watch you go through through the whoops to see if you are bottoming and do some trial an error testing both ways on the rebound.
Compression is speed sensitive. The faster you go, the faster it needs to be. If your a good rider on stock suspension settings. You probably need it faster.
