1 - 20 of 56 Posts
Moderator
First Two photos were the before pictures. Purchased the bike out of PA. Took it home and started stripping it down. Only rode it for a test ride before I bought it. So needless to say I’m getting anxious too get it done!
93084
93085
93086
93087
93088
93089
93090
93091
93092
93093
More pictures to come through the build. Everything has been powder coated. All new stainless steel ProBolts throughout. Everything new from ground up. Slow build but it’s coming along. Here is a list off the top of my heads what’s been added.
  • Pro Taper Woods bend bars
  • Magura HYMEC clutch
  • Tether Kill switch
  • Push button start
  • Race Cut harness
  • Custom Fourwerx seat ( not mounted yet )
  • Maier White plastics ( not mounted yet )
  • Fourwerx carbon fiber radiator shrouds ( not mounted yet )
  • Barker Performance exhaust black powder coated ( not mounted yet )
  • Maxxis Razor 2 front/ rear wheels ( not mounted yet )
  • Hiper tech 3 real dual bead locks ( not mounted yet )
  • Hiper tech 3 single front bead locks ( not mounted yet )
  • Houser slicast xc a-arms ( off to powder )
  • Houser pro bounce nerf bars ( off to powder )
  • Ported Head
  • CP Carrillo 98mm 13.75:1 compression piston
  • CP Carrillo billet rod
  • Millenium Technologies bored, fitted and re-plated OEM Cylinder
  • Crankworks balanced crank
  • RP Race XC Intake
  • Vortex ECU
  • FOX Evol Front Shocks
  • BNR rear spring
  • Outwear shock covers
  • 38 Motorsports Oil Vent tank
  • Glann Innovations swingarm tensioner
  • Glann Innovations front sprocket guard
  • CRF belly skid
  • All new tapered front wheel bearings
  • New rear carrier bearings
  • Precision steering stabilizer
  • Stock axle stripped and rainbow zinc coated ( not mounted yet )
  • Galfer stainless front/ rear brake lines
  • Renthal 13 tooth front sprocket
  • Vortex 38 steel rear sprocket
Wow, that is going to be one serious build! Looking forward to the final product.
  • Like
Reactions: atvman8351
Moderator
Discussion Starter #9
Didn’t get very far tonight. Got the axle in, sprocket and disk brake mounted, rebuilt caliper and stainless brake line on.
93116
93117
93118
93119
Hipers always look so badass! Hopefully they perform as good as they look.
Moderator
Discussion Starter #13
They sure do! I’ve always had great luck with them. I like the fact the tech 3’s are modular so if you damage a bead lock ring or inner/outer you can replace them fairly reasonable. Sure wish they made green bead lock rings still though. Definitely worth the price.
Badass seat!
I am new to this forum so I am just catching up to your build. Your detailed work is impressive. Much respect.
1 - 20 of 56 Posts
