My YFZ when i start it in the morning and it is cold outside the first time you pull in the clutch and put it in gear it dies right away like the clutch is not pulled in, has anyone else had this problem, any fix to it.
The clutches are just stuck together they do that sometimes when they are new or the oil is very cold. Put it in nuetral and let it warm up. It should be ok.
there is no "fix". the oil and clutch parts are cold and sticking. either pull the clutch lever in and out several time before you put in in gear, let the engine and oil warm up more before you ride or move south for the winter... j/k on the last one
i had this prob posted a few days ago and just let her warm up for 5-10 min and the clutch works fine.
whatever you do DONT keep trying to start it in gear when you know its cold and gonna lurch a new starter for this thing aint cheap :O
The reason you would start it in gear is that you would want to ride it right away. Bad idea with a cold race engine.
