I know that your asking about the yfz450r but I just done a ton of research on clutches for a 2012 yfz450 and it should be similar I'm guessing for your quad..
After reading a ton of comments I was lead to believe that the oem yamaha clutch was the best way to go but I continued reading and found out the clutch basket is made from inexpensive die casting that wear quickly and I'm guessing would wear out your clutch plates and springs quickly, wiseco explains all this when you look up their clutch basket and they make a way more durable basket that comes with a lifetime warranty..
Back to the clutch parts, I was about to get stock oem clutch steel and fiber kit and it was fairly expensive at $190 cad and continued reading up on oem clutches and started finding out that some cheaper aftermarket clutch kits are made better and hold up longer than oem.. so I got an alba clutch, this kit is made with stiffer springs and they claim that yamaha actually contacted alba about their clutch kits and brought them back to Japan to do testing..
They claim that these clutch kits hold up in 1000 km baja races and keep going, not to mention this kit cost me only $115 and it comes with better springs, better steel, better fibers and a gasket for the clutch plate..
I also came across these tusk clutch kits which would be the cheapest option for me but there are way too many negative reviews leading me to believe stock would be way better than those..
This is all new to me and yesterday is the first time I've taken apart a clutch to inspect it but I have been riding bikes all my life.. never had a clutch burn out so we will see in a couple weeks how this Alba clutch kit works out..
This is the kit I ordered and I'm hoping it fits in a stock 2012 yfz450 without any headaches like I had with my rotor and brakes..
