Put +1 stem and med. tag bend. The stock cable is just a hair too short. Bought the dirt bike cable and I can't even get it on. Who else makes longer clutch cables?
Tried also the dirtbike cable, doesn't fit either. No I found another solution. I've rerouted the stock cable. Stock it goes in front of the handlebar, behind the neutral and temp light under the fuel thank. If you cut a small piece of plastic of your fuel tank cover, you can route it behind your handlebar
