generally you want to go up one size with your pilot jet when doing the cam mod
So your saying my bike isn't going to run properly unless i do this. What happens when i turn the screw on the bottom of the carb? More/Less fuel right???generally you want to go up one size with your pilot jet when doing the cam mod[/b]
did you take the slide out of the carb when you cleaned it?[/b]
thats not itadjust your idle up[/b]
thats not it
go up on your pilot. Cam-mod makes it run lean. The choke gives a hbit more fuel to start when cold right so if you richen the mixture it will run perfect. Thats my 2 cents[/b]
thats not it
