1 - 11 of 11 Posts
any one out there had problems with there yfz 450 frames.........broke mine this past weekend on a 60 ft double............ :( :(
Broke mine last weekend by hitting a tree with the right front wheel. Ripped the shocl mount completly off. I havnt had it looked at yet to see if it bent the frame.
C
Guest
ouch! did u come up short?
u should hsve got it gusseted.well to late now. :(
Where exactly did you crack the frame? My brother Merriman and I had to totally rebuild his yfz (the frame) due to a crash he had at a track, and while it was apart we gusseted the entire frame, including adding a vertical riser between the radiator and the motor. I will talk it over with him tonight to see if we would like to take on the task of rebuilding cracked/broken frames. I can gaurentee that we will beat NE1'S price if we decide to go that route. I will get back to you tonight to up date you if you would be interested. If you would like to check out are work, look at the QOTM for december.
1 - 11 of 11 Posts
