As the title says, the bike will not fire up, just had the valves re-done and the timing is set right at TDC. I had the carb apart where the AP plunger is and its all cleaned.
The bowl is filling, but the AP is not squirting. Though the bike would still start even if the AP was clogged.
I checked the pilot and main jets and they are both free of blockage.
Spark is good.
Compression is good.
Bike simply turns over and over without any sign of life.
Jetting is the same as it was before i had the valves done so jetting is not the problem.
Any ideas?
About to try some fresh fuel, and see if thats the problem. Fingers crossed.
Discussion Starter · #2 ·
Fresh gas and it backfires a little more, but still a no go.
Any help please?
Terse? You still here?
Any help please?
