Bike will not run! Helllllp!
374 Views 6 Replies 3 Participants Last post by  alex450r22
So I've got a 2014 yfz450r. Bought it not running. When I turn the key on I didn't hear the fuel pump turn on so I tested it and turns out it'd bad. Put in a new pump and tried to start it. No luck. Its like the fuel isn't getting past the injector. Or there isn't enough fuel pressure. I hooked up an airline to the fuel inlet hose that i disconnected from the tank and while putting air to it and rolling it Over and it kicked a farted a little bit. It did have really bad old gas in it also. I put fresh gas in. If I spray carb cleaner into the intake it will run for a second. Any ideas? Where the heck is the fuel pressure regulator?
Check wella
Check wella
What is wella? I don't know alot about these bikes.
Have you check the connects to the actual fuel pump? I came across a vid on YouTube from “ononewheel7” where he solders the connection together because the eventually come off from hard riding and obviously will definitely not start
I disconnected the fuel line at the tank and roll it over and fuel shoots out of it. So its definitely working. That same line I took off, when I put air from a compressor in it. It will run for a min. Almost like there's not enough fuel pressure or something. Or the injector is blocked. Not sure.
Have you checked other things like timing ?
