Now that I got my bike charging correctly I can let it run a lil bit longer. After letting it idle for a little bit and try to blip the throttle it sometimes shuts off, in which case some people describe that as bogging down perhaps. I don't think the zip tie mod or cam mod have been done. If doing so do you guy's believe it will eliminate my problem?
I’d probably start with checking your Throttle Position Sensor voltage. There are multiple threads on here explaining a cheap/free, easy way to check it and adjust it. All it really takes is a couple safety pins, screwdriver and a multimeter. Also worth checking out youtube, lots of videos for this as well.
If you can’t get within specs (my ‘19 is between .679 and .681), a new TPS is possibly needed and that runs ~$90
Carb bike
What year?
Can you post a video?
Could be a few things, but maybe a video will help. Could be jetting, tors, TB, leak
