Little frustrated right now. This is why i always buy new... Bought an engine from a guy. he said the engine barely had 5 hours on it. He said it had a CP 13.5:1 piston on a Athena Big bore. I didn't like the port job he had on it so i sent the head off. I then saw that it had blow-by on the intake side into the coolant passages. He didn't tell me this so I inspected more. I see the piston is sticking over the cylinder... 0.033 inches over (with the cylinder bolted down) to be exact. So now i am off measuring everything to get it into the right specs...
Here are my measurements:
Piston sticking over 0.033 in./ 0.8382 mm
Base Gasket 0.0145 in./ 0.3693 mm
Head Gasket 0.028 in./ 0.7112 mm
That puts me at -0.005 in. / -0.127 mm squish... not happy. that's contact. Inspected everything. Seems to be fine physically...
Where do you even get a base gasket at 0.0145 in/ 0.37 mm???
This guy's engine builder must have tried really hard to mess this thing up.
Anyway. I need a few things.
Just to be clear, squish needs to be 0.030 - 0.040 inches? or millimeters?
Inches is what i have been reading.
For reference, 0.040 inches squish = 1.016 mm squish
So if i stack 2 athena gaskets 2(.67 mm per Terse)= 1.34 mm
that would make my clearance = 0.134 mm (now below the cylinder)
Add a new head gasket = 0.711 mm
That puts me at 0.845 mm or 0.033 inches squish.
Can anyone verify that the athena gaskets are 0.67 mm thick?
Does anyone know what head gasket is 0.71 mm thick?
And where do i order these gaskets?
Like i said i have never seen a base gasket so small, so i have no idea where this guy's engine builder got the gaskets.
Now, another issue.
How do i know what size the big bore is? Does athena make a 470? or just a 480? The reason i ask is, the Cylinder is 97.78 mm and the Piston is 97.2 mm. CP makes a 97 mm 13.5:1 piston, M1031, and a 98 mm 13.5:1 piston, M1051. The only marking i could find is MX98 on the back side, so i would assume this is a 98 mm piston. I just need to know so i can order the right gaskets.
Now, another issue.
