2021 yfz450
Hi guys,
i was hoping i can get some suggestions on what vortex settings i should run
i have the 2021 yfz450
Mods :
Yoshi rs2 full system
Fci intake
Hotrot crank
Athena stock bore cylinder
Cp 12.5.1 high compress piston
Stage 2 cams
Ais delete
Oil return tank
Vortex
so lately i destoryed the crack bearing and not sure what happend there .. i was cruising around when it happend ..
The pump gas we have is around 91 octane
what settings should i run on the vortex ..?
Thanks in advanced
Yo man thanks for your reply,
i will give it a try .. i was running 8-667 witch was running great .. no problem just not sure if that caused my crankbearing to explode ..?
Thanks
I doubt the fuel settings had anything to do with the crank bearing exploding. How often did you change the oil? I normally changed mine after every 1-2 tanks of fuel or quicker if I knocked on the rev limiter multiple times in a day.
