Axle Bearing Change Help
1443 Views 3 Replies 3 Participants Last post by  sidewinder
I need new rear axle bearings. are these easy to change? can i do it myself? also does anyone have a guide on how to do this? and add anything else i should know
You will need a press to get the bearings in and out of the carrier.
You can also go to a Harbor Freight and buy a bearing puller tool that will get the old bearings out. To replace them, just use a piece of wood and place it against the new bearings as you hammer them in. works like a champ.
QUOTE (code918 @ Mar 17 2009, 11:50 PM) index.php?act=findpost&pid=759098
To replace them, just use a piece of wood and place it against the new bearings as you hammer them in. works like a champ.[/b]
As long as you don't damage them hammering them in. :shocker:
