Anyone take off there warning stickers that come on the YFZ YET? Are they like the blaster or the banshee you can drill out the pop-rivits and then there will be just four holes in the corner or wll there be like a frame where it once was?
Drill out the rivets and they come right off. they do have some kind of adhesive on them though.
use a pair of pliers of pliers to hold the back of the pop to stop it spinning.
Geoff.
Easy way, use a pair of wire cutters/dikes :O (old ones) and cut the rivits off from the under side. Then just pull them out, they cut like butter.
I slammed my offroad plate over one of them, and put some custom stickers on the rest of them.
Like anyone reads that crap anyways :wtf
I took mine off, and replaced them with aluminum diamond plate. Looks much better, and was easy to do. Took me under an hour to do them all. :)
I just put the drill in and while drilling moved the drill bit sideways back and forth and pop it goes right through...
Just left mine plain...
I just removed mine a little while ago, best thing to do is hold the back of them with a pair of pliers or else the drill will spin the rivit and heat up and melt a bigger hole than the one that there. I personally like the look of having nothing there.
so far I like Amerigins idea, using Dikes?
