Has any one installed a flywheel weight yet? This ia a mod that I am considering. I ride in the woods with real tight and technical trails and I am hoping this will help out.
I think you can either swap out the fly wheel or add weight.
Discussion Starter #6
It makes it harder to stall but i'm not sure about reving quicker at low rpms. I dont want to lose the quick reving ability the motor has. In the past alot of guys put flywheel weights on the yzf426s.
Ok heres what it does:
"Adding a flywheel weight will increase the rotating mass, or inertia, of the motor. The result is an engine that is a little slower to rev, has more controllable power delivery and less hard hitting power, a more usable low to mid-range, and is less likely to stall at slow speeds or with the rear brake. What you will feel is better traction when it is slippery or hard pack, a torquier and broader powerband, the top end power on many bikes will be improved with less tendency to lose RPM's when climbing or hitting obstacles. The easier to control power will help you conserve your strength and energy, plus many bikes start easier with the added weight."
