I'l be picking up my new yfz in two weeks, and had a few jetting questions. I'll be using the stock exhuast for about a month,but will install a K&N filter and remove airlid cover. The dealer said they would jet the bike for me. I dont know if they'll remove the baffle or not, if not I will. Will I need to rejet?
for starters...if you leave the quad all stock try out a 165 main, move the clip up one, 45 pilot, and 2 turns out on screw...see how it runs then. if you remove the baffle try starting with a 168 main and everything else the same. if you put the kn on, remove lid, and have the baffle off i would try a 170 main and the same for everything else. should get you in the ball park.
i'm also getting the yz cam installed at the dealer. I'll try to remove the baffle before they jet it.thanks for the info, I geuss it would've helped to say were i would be riding..........GLAMIS!
