1 - 9 of 9 Posts
I know it's not a YFZ-R... and I didn't get rid of mine either, it's so nice having both.
Picked up an 02 black and white banshee last night, FMF pipes, boost bottle (it's gotta go), open airbox with K&N, TORS eliminated, chassis guards, and 22" tires all around. Needs a little love, but what used quad doesn't? This is my second one, slightly less modified than the first one. It's also nice having something that isn't as nice as the 2016 YFZ to just take out and beat up on.
Got it for a good price because it didn't run 100%. Idle was set too high, carbs were dirty and out of sync, plug wires had poor contact, and the slides were in backwards. Not even an hour of work, little bit of hardware, gallon and a half of fresh gas, little carb tuning and it's a one kick machine.
I'm happy with where my R is at, it's perfect for me the way it is. So it was nice to take on another little project. I already ordered a stock crossover tube, and the left side fender support that was missing for the shee. Eventually I'll probably sell it. I'd much rather have the anniversary edition banshee to match my YFZ anyways.
never mind read it wrong.
Discussion Starter #5
Properly eliminated the TORS and parking brake system by unraveling the entire wiring harness and removing all the splices as well as removing the pin from the connector. Also cleaned up some hacked wiring and a missing connector for the left front headlight. Previous owner said the lights never worked. After laying out the harness, I figured out they had the voltage regulator wire plugged into the brake light wiring.... Oops. Also got a stock crossover tube to replace the boost bottle and a Honda thumb throttle assembly to ease the fatigue.
Next project will be to retrofit dual piston front calipers from a carb YFZ 450, and also possibly the brake master cylinder. Would like to attempt to fit a right front YFZ caliper on the rear to get some better braking power.
It's very interesting going from the banshee to the YFZ. It's like hopping out of a big block chevelle (banshee) and getting into a new corvette (YFZ), they both haul ass, get your heart going, and put a smile on your face, but they do it in two different ways with two completely different feels.
Discussion Starter #6
Some updates. Trying to get all the jankyness out of the bike.
Added YFZ 450 front calipers and master cylinder. Great upgrade. Ordered some YFZ450R stock handlebars as well.
Engine only had 100 psi compression in both cylinders. All OEM Yamaha, never opened up engine, 64mm bore. Crank had play, cylinders had some rust from sitting, pistons looked fairly new still. New hot rods crankshaft, set of rings, honed cylinders, cut .010 off the head, back to 140 psi. Had under $500 into this refresh using all OEM gaskets/hot rods crankshaft, also including a water pump impeller, new K&N air filter, and another pair of main jets.
Got to meet up with ATVman a few weeks ago. Really nice guy, gave me a great deal on a set of Duro Top Fighters. He also hooked me up with a Lonestar sway bar. If you're reading this... thanks again! Bike looks a hundred times better now with these flat track tires!
Used some carb cleaner and goof off and got the white to look pretty good again. It had a nasty look to it, was more like cream color from sitting outside for so long. Also got a pair of OEM heel guards for cheap. I prefer those over the nerf bars.
Next round of mods, is a set of Alba +2/+1 arms, tie rod ends, new front rotors and pads, YFZ 450r handlebars and adapters, and a hide a key. Axle will follow, just not sure which one to go with yet.
Discussion Starter #8
I have a bunch of banshee parts. What else do you need?
I mean, I don't NEED much.... but what do you have?
Only thing on the needs list that I haven't found yet is a new kick start assembly. Might spring for a billet one. I don't know. Got any good kickers?
1 - 9 of 9 Posts
