alright, this one may come in handy some day for one of you.
Well, got my Tag T2 bars in finally and went to install them late tonight........big ride in the morning and national holiday where i live so nothing will be open. low and behold i decided to make sure my clutch lever was secured........Damn these bolts are THIN. anyways, snapped one off.
If you still have your original grab bar.......with the reflectors on it........take a pair of ***** and cut the reflector apart. the screw inside while it has a flat face on it will fit in a pinch until you can get a replacement. I can't believe i broke the damn thing :(
to keep from doing this i do the same thing i used to do on my dirtbikes keep it a little loose so with some pressure u can push it down.That away if u ever flip it (i hope not though) the levers will roll down instead of snapping off
