1 - 13 of 13 Posts
YFZ450 Alba a-arms are long travel a-arms that include a bracket that allows you to use your stock shocks or standard travel shocks also.
Get 10% OFF on our website with forum discount code = YFZ450ALBA
Forum price is $360 shipped to the continental USA. We do ship world wide.
http://teamalbaracing.com/i-13567053-yamaha-yfz-450-adjustable-long-travel-a-arm.html
We believe our a arms are among the best you can buy. We know they are the best you can buy for the price! With our radical new adapter you can run either stock or long travel shocks. Add the quality materials and construction, full adjustabilty and high ground clearance and you know they can't be beat!
WIDTH - +2 each side for a 4" wider front end
CAMBER - fully adjustable thru the lower ball joints. No need to remove the arms to make the adjustment like you have to with many other brands.
CASTER - 3 way adjustable by changing spacers on the upper a arm - all around, MX, desert
GULLWING SHAPE - The swept design of our arms give you the maximum possible clearance in ruts and other obstacles. When other a arms will drag thru the high ridges these will glid over the top - not to mention the design looks badass.
LONG/STANDARD TRAVEL - Exclusive to Alba. Can't afford shocks yet? Use the adapter and run your stock shocks or your standard travel aftermarket shocks. When you are ready to upgrade to long travel shocks take the adapter out and mount your long travel shocks -- no need to go out and spend another $700.00 on long travel a arms. Save big $$$ - Did you know most shock companies charge the same for long travel shocks as standard travel shocks? With Alba you can get your long travel system from the get go and save hundreds of dollars. You don't have to settle for a standard length system. Once you ride long travel you will never go back. The difference is incredible. One picture shows the a arms with the standard travel adapter installed. Do not use it for long travel.
CONSTRUCTION MATERIALS - We use .120 wall 4130 chromoly tubing, delrin bushings and the highest quality ball joints. The arms are powdercoated gloss black. NEW - WE HAVE UPGRADED THE STEEL SLEEVES TO CHROME. YOU GET LONGER LIFE AND LESS STICTION
LIFETIME WARRANTY - Our a arms have a lifetime warranty for materials and craftsmanship. If you hit something and they bend we will not cover that. If you are riding and a weld cracks we will cover that. Wear items are not covered - ball joints, and delron bushings. This is backed by Alba Racing which has been in business for 20 years.
Discussion Starter #5
The 04-05 use 04-05 tie rods and the 06+ use 06+. If you replace your joints on the tie rods you can use 06 tie rods on a 04-05.
So with this kit does it come with brake lines and stuff or is it just the a-arms? also how do you grease the a-arm bolts? I noticed that there are no zerk fittings to grease them.
Discussion Starter #8 (Edited)
We will sell them how ever you want. We have a kit that includes lines, clamps, and the arms. We also sell them as just the arms. The kit with lines and clamps is about $50 additional. The bushings are delrin which do not use lube. We have upgraded our bushings about a year ago and they last a long time. We also recently started chrome plating the steel sleeves that the bushings go on which drastically extends life of the bushings. These are built to last.
Possibly ever guna make like a xc width? Like +1 or +0.5?
1 - 13 of 13 Posts
