So I took my AIS off and started the motor to see if there was a code thrown for it being unplugged, which there wasn't, and to see how it ran.
This is an EGR system. Exhaust gases are pushed to the valve and the computer tells it when to open, then they are sucked in the intake from the vacuum created by the piston. Calling it "AIS" is misleading, there is no "air" being injected, only exhaust.
All this most likely happens at lower rpms and increases the chances of the bog/stalling events this motor has.
I copied the shape of the metal gasket on some aluminum plate I had left over, drilled the holes, shortened the alan bolts about 1/4" and put it back together. I used Black silicon in the airbox hole and trimmed it off flush after it dried. Pretty much free mod.
Only thing is the cables are dangling near the pipe, I will zip tie em up somehow.
Before you say it.....its totally reversible for the joke warranty that covers nothing.
