Bolts are torqued to 7.2lbs
I removed my front and rear fenders, side covers, tank cover, fuel tanks shield under tank and fuel tank to get to my AIS. There is a rubber and plastic cap that is attached to the back side of the tank that is used for sealing off the tank fitting and fuel line. I cut the finger off of a black rubber shop glove and zip tied it over the harness and it almost looks like it came from the factory that way. Push the fittings on the fuel line up then remove the lines from the tank. Be careful because the plastic is brittle. Good luck!
You have 2 options:
1. Gytr-pros clean, cons no cable holder or metal breather pipe holder mount
2. 2013 holder- reverse of above
