Need your advice! I put 8 inch holeshots on the rear deciding between sprockets. Change the front or rear?
38/15 = 2.53 (changing the front sprocket)
36/14 = 2.57 (changing the rear sprocket)
I weight 220lbs and looking for the best gearing for motocross.
Thanks
I would change the rear. increasing the front would decrease the clearance to the case which isn't problem but would make me feel safer and decreasing the rear would give you more ground clerance which also isn't really an issue with motocross. :what
I thought about it more and I think now I would change the front so then if it wasn't exactly right you could fine tune it by going up or down a tooth in the rear.
