Where can I find a good needle and jet kit that isn't GYTR, I found some at CT racing but they couldn't tell me if it would work with an FMF pipe so I didn't buy it.
call bob at magnolia tractor..site sponsor, he has the needle and jets your looking for with a discount even
Becuase I have installed a air intake kit that removes the airbox completely. I called dyno jet and they do not make jets big enough to accomodate this modification. If you have exhaust and run with the airbox lid off, the kit will work just fine.
Check out the for sale form, it is explained in there.
I would buy the YZ needle and a 45 pilot and a few 165-175 mains to start.
Should be able to get everything for less than $30 bucks from Bob @ Magnolia, and with these jets you will have alot easier time getting help with jetting than with the Dyno kit (sorry OCBC)
Pahrump has it right. Kits have alot of jets you do not need and usually DO NOT have the ones you need.
Calculate your range with the mods you have and info in the jetting posts. Adjust for altitude, and buy 3 or 4 jets in YOUR range.
Then install the NCVQ needle and you will have a fire breathin animal.
