2021 YFZ 450r Must have mods.
12527 Views 81 Replies 17 Participants Last post by  staxpoker
Hey Y’all,
Im picking up my new 2021 YFZ 450r se next week and am wondering what are some must have mods? I got the HMF full exhaust, Vortex ecu, FCI intake and some nerf bars. Any help would be appreciated.
Thanks!
1 - 20 of 82 Posts
Those are good mods,what kind of riding do you do?
Personally, I would do suspension, stabilizer... and possibly a stem with flex bars or a precision clamp before anything else. If you are comfortable you will go faster and have more control.
Pipe fci vortex steering damper 38 motorsport oil breather and ais delete. Also 8inch bead lock rr rims and good tyres all round would be a good choice. stockers wouldnt be the best
clutch basket so you don't grenade the current Garbo basket.
  • Like
Reactions: 1
yes get rid of the stock slipper clutch. Swap it out with the 09-13 basket and pressure plate and all related items. Dont delay on doing this. Its a ticking time-bomb.
I've swapped to the '09 clutch basket on my 2020. Haven't however done the "pressure plate and all related items". Is that truly necessary because it's the first I'm hearing about it?
I don’t know how you did that, the slipper assist factory clutch that comes in the newer efi models has three bolts and springs and 3 rubber dampeners in the pressure plate. The ‘09 basket and pressure plate has 6 bolts and springs. Just wondering?
So you can just put the 09 basket in thrust washer in and one other washer and just drop the slipper clutch right in. Bnr sells a kit like that with those 3 oem parts and plenty of people apparently have been doing this
You can just do the basket
Not ever 3 bolts. 3 RIVETS that suck
Oh, I did the complete swap. Wanted to get away from the 3 bolt deal.
I just ordered a full hinson don't want to risk anything
I had to order the 09 stock basket because the Hinson so I was told does not come with the primary drive gear. And the gear that’s on the Slipper basket won’t work, again so I was told. Just FYI. I also went with Rekluse fibers and steels and springs.
  • Like
Reactions: 1
Yeah no you grind the rivets off the slipper clutch and transfer the gear to there basket and it bolts on
Beside hinson wouldn't sell a full kit that you need to buy other parts for it.
You ordered the 09-13 kit? If so did the basket come with the gear?
No 2014 to 2020 kit
Hinson makes/made a basket that did include the Gear. I purchased one in December 2020 but I do not find it on their site anymore. Maybe a call to them and see if it’s just not advertised anymore? Just a thought. Below is the Part Number for reference but this is the “09” Basket and gear setup. Does include the appropriate thrust washer as well in this kit. Gear is bolted to and pinned from their factory.
1 - 20 of 82 Posts
