Doing my first oil change for my new bike. So I checked the manuel for the oil type and I know its 10w-40 Yamalube however it doesn't say weather it should be the full synthetic high proformance 4t or the regular all purpose yamalube. So witch one do you guys recommend and use?
Also I noticed in the manuel for this bike (again 2020 yfz450r se) it only shows ONE oil drain bolt... isn't it usually 2? Or is this new year model legitimately only 1?
Any help would be great!! Thank you.
I don’t know what manual you’re reading but yes there are 2 drain bolts. One underneath the shifter (left side) and one in the center near the front of the engine.
STOCK UP ON COPPER CRUSH WASHERS. I always install new ones each oil change. I just bought a pack of 30 on amazon same size thickness and they look exactly like OEM. BUT A LOT CHEAPER.
Either one but don't use anything with friction modifiers. I use Walmart oil, three changes for 14$.
